Reply
R8000 - Router Page Suggestion - Add LAN Port Connectivity Page
ThePie
On the router page under advanced features there should be a place to view the LAN ports and see which ports are being used. I have the issue right now of only being able to check the router via VPN so I can not physically see what is plugged into the router. This would help users see if a device has been unplugged from one of the LAN ports.
Message 1 of 3
TheEther
Guru
Re: R8000 - Router Page Suggestion - Add LAN Port Connectivity Page
IIRC, you should be able to see which ports are in use on the Attached Devices as well as the Show Statistics pages.
Message 2 of 3
ThePie
Ah yes, show statistics is what I was looking for. It would be nice if that was made easier to find at least.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1539 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
