Reply
R8000 Slow Wired Speeds
Hello,
I have the NightHawk X6 Tri band R8000 router. I have Comcast Gigbit Internet. When I plug my ROG laptop directly to the comcast modem (which was just installed today) I get speeds upto 980mbps down and 51mbps up. However, when i wire into my noghthawk i get 420mbps down and 32mbps up.
I have QOS disabled, Traffic meter disabled, i have set my ISP speeds to 1000mbps and my MTU is 1500. I do not have smart connect or metering on. I updated my firmware to latest and rebooted my router multiple times. What am I missing?
is this router not capable of gigabit speeds?
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 4
Re: R8000 Slow Wired Speeds
Greetings,
Not sure which model you have?  Subject R8000, Sig R8000P?  Either way, both are capable of gigabit speeds.
Is this a new router?  I would suggest reseting the router to defaults.  This is recommended if after a FW update you experience unexpected/undesired behavior.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.64 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 4
Nighthawk X6 R8000 FW 1.04.18. Router is about 2 years old. I have not reset the router yet. I will try that and update results. Thanks for teh reply.
Message 3 of 4
Ok so i did the factory reset like you suggested. I had to do it 4 times before it took. I was able to get my speeds to 419 down and 42 up. That is wireless from my Asus ROG Stryx to my Nighthawk X6 router. I have comcast like i stated and when i plug my laptop directly to the comcast modem (which is in bridged mode so i can use my router) I get speeds up to 980 down and 50up. When I wire in to the router I get maybe 680down and 45up. What more can anyone suggest that i do to get more performance out of this router before i decice to give it away and get another brand.?
Please keep in mind i have tried all the suggestion so far. Followed them to a T and did some i just learned about. It doubled my speed but i am still not close 800-900mbpsdown. Heck, I would even take 700mbps down at this point,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 932 views
  • 1 kudo
  • 2 in conversation
Announcements
