Reply
R8000 Slow Wireless/Wired connection
djblack91
I have factory reset the router three times. Set it up through the wizard and used the Genie. I have manually updated the fireware 3 times as well. What can I do to fix this before I return the router.
Message 1 of 2
HiSpeed
Guide
Re: R8000 Slow Wireless/Wired connection
Hi,
What do you mean exactly with "slow" ?
What are you testing, the ADSL line speed or the pure WLAN/LAN speed ?
● Netgear R7000 (Root Router)
● TP-Link Archer C7 v2 (WDS Bridge)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2127 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
