- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 Slow Wireless & Wired,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
A couple days ago I upgraded my router from the Linksys EA3500 N750, to the Nighthawk X6 R8000. I have 100mbs service and when I'm wired dirrectly to the modem I do see between 93-100mbps depending on when I run the speedtest.net.
The moment I put the router betweent he PC and the modem the connection speed drops to around 60mbps for wired and no better than 27mbps for wireless. (Download)
At first I thought it was the router because the last router never had this problem so I returned the first R8000 and exchanged it for another R8000.
I tried 4 or 5 of the previous Firmware available on netgears website with no change at all. latest being V1.0.2.46_1.0.97
Can anyone shed some light on what's going on?
Thanks.
M
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R8000 Slow Wireless & Wired,
I just upgraded mine to R8000 too and not having this problem. Did you set up the R8000 to replace the service provider modem's router/wifi features too, by using their Auto-config (Genie) software to auto detect and set it up? Could you advice how are the devices being inter-connected physically? With more info then would be able to help. The patch cords (preferably good quality Cat 5e or Cat 6 ones) used to connect them up plays a part too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I did use the autodetect setting within the routerlogin.net genie
The modem is a Surfboard 6141 (4mo old) and worked in place with the previous router just days earlier.
They are connected normally. Wall-modem-5e Patch-Router-wireless (or hardwired with a new cable)
I've used 3 different new patch cords.
Also, this is the second R8000 with the same results even though the previous router was at normal speeds. If I take the router out of the loop, I am seeing 100mbps service dirrectly through the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just to confirm, you connected the router to your modem via the yellow internet port right? If it is connected correctly and set up properly, then unlikely to have this problem and you should be able to achieve the available bandwidth of your internet connection.
As a next step, suggest that you try by resetting your R8000 router by pressing the reset button for at least 8-10 seconds until you see all the lights go off , then power off the R8000 and wait for 10 seconds before powering it up, then do the setup again. This would solve the problem sometimes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have reset the moden a few times. I also did it to the last R8000 I returned a few days ago. I can't imagine that the store would have two faulty r8000's but it's the only thing I can imagine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
BTW, are you a techie that is able to check the setup manually after the auto-setup. If you have already set it up and using it, you could try to access the router by keying in the default IP address 192.168.1.1 to access the router setup page, default ID is admin and Password is password. Check the settings to see if there is anything unusual with any of the settings.
Have you tried calling their tech support then? Guess that is the other only thing left that you can do then, to let them guide you through the troubleshooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am able to set up the connection manually but there was no change. Complete resets and all versions of the firmware available did not fix the problems.
In the end I exchanged the router a second time (3rd R8000) and managed to have similar issues but the connection speeds were increased by a little on all ports but 4. (previously I had no issues with the router the nighthawk replaced.)
Wired
Port1 117mbps
Port2 98mpbs
Port3 80mpbs
Port4 63mbps
Wireless
2.4 60mbps
5-1 55mbps
5-2 40mbps
After leaving the connection up for several hours as requested by Netgear tech support the speeds actually went down back to where they were previously with the 27mbps on wireless and 60ish mbps wired.
After 3 R8000's I gave up and bought a Linksys ea8500. Magically, all of my speeds are within spec and acceptible.
I have no explination why the R8000 was such a PITA for me. My wife has literally sold hundreds of these routers and has never had any of them returned for the issues we were having.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yup, this is really strange and one can't derive a logical reason as to why this is happening to you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @LinuxGuy,
Please try the latest firmware for R8000.
http://kb.netgear.com/app/answers/detail/a_id/3001
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you for your reply but you didn't read anything I wrote.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi there,
I ma having the same problem the previous gentleman described. I bought my 2nd R8000 now, and still have the same issue. Can anyone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I believe you have read though the earlier posts and have tried out the different means described there to resolve the problem yah?
If you have already done so on those steps, have you tried connecting directly to your modem or router directly via a Cat 5E or Cat 6 patch cord and perform a speedtest to check your bandwidth (to the ISP) at the modem and directly via the router's wired connection? If you haven't done so, pls check this first and let me know. Is your connection speed the same for wireless and wired?
Do note that a full proper router reset is very important as it solves many funny problems most of the time.
It will be helpful if you could describe a little more about your problem, something that is unique and doesn't seem to be normal to the best of your knowledge.
BTW, what do you meant by you bought your 2nd R8000 now? You already have a R8000 bought earlier and is using it now without problems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi AZ_Life,
Try to reset the router to factory default and manually reconfigure the device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi AZ_Life,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm also having the same exact issues as the OP. Literally, the exact same issues.
The support on this forum is laughable and it seems the Mods don't even read the posts before responding.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for the response.
I've updated my settings, so hopefully this works!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi
I have the same problem - turning off QoS do help a bit (a lot in fact). However, running several tests - directly on the modem, turning off Wi-fi usinge an other routher clearsly shows that the R8000 "take out" some percentage of the max speed. I will need to return regarding the specific numbers... as I also have an issue getting max speed (1/1GB) from my provider.
Anyway, I spent a lot of time reading reviews of this and other routhers, and I did not see this problem comming. :-/
Regards Per
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks - Reading a lot of stuff on the net., I now found one more small problem. It appears that I was given a CAT5 cable with the modem - and when I changed that to a CAT6 one a lot happend!
Also I have tried to set the threshold, but the max is 1000mb - so I can not set it it to 2-3 times what I am suposed to get.
Finally I had to power off/on the X6, and that appears to give completely new, and better, results.
I'm now trying to upgrade my switches and cables, as some also appears to be defect and I will return with a more fulfilling report with speed reading etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hope this helps
User | Count |
22 | |
14 | |
9 | |
8 | |
4 |
