Reply
R8000-V1.0.0.102_1.0.45 Released Official
cc999
Message 1 of 9
cavemankr
Re: R8000-V1.0.0.102_1.0.45 Released Official
is there a release note?
Message 2 of 9
cavemankr
Never mind. It looks like this is same version as the previous beta firmware.
Message 3 of 9
PickMe4Beta
NETGEAR Employee Retired
No change from Beta 102 release
Message 4 of 9
PickMe4Beta
R8000 FW V1.0.0.102 Official Release
http://support.netgear.com/product/r8000
Download
http://www.downloads.netgear.com/files/GDC/R8000/R8000-V1.0.0.102_1.0.45.zip
Release notes –
(1) Improves the wireless connection stability.
(2) Improves the USB 3.0 IOT and the stability for file access.
(3) Fixes some IPv6 connection issues that happen in certain cases.
(4) Adds support for some IPv6 service over PPPoE.
(5) Improves Time Machine support.
(6) Fixes the issue that may consume more battery power of mobile devices connected to router.
(7) Fixes the issue that disallows multiple port forwarding rules to the same internal port.
(8) Fixes some GUI display issues in the Show Statistics window.
(9) Fixes the connection issue with Sonos speaker.
(10) Removes the detection function for AP mode.
No Factory reset to default is required.
Post any issues experienced after installing this V1.0.0.102 release in this thread.
Regards
PickMe4Beta
NETGEAR Employee
Message 5 of 9
IHancock
Novice
Having been running this for the last couple of weeks I have to say stability is definitely way better.
Time machine has crapped out on me and is currently very confused. Not sure if this Apple or the router at fault as my Wife's backups are working flawlessly on the router now.
Message 6 of 9
chungsm
Today I install the new firmware , bad thing happen, the internet disconnect every 30mins . I don't know whats wrong , change back to pervious fw 1.44 , working fine.
Message 7 of 9
kd0bno
I have not had any satisfaction with this release. Every day I come home after work and the device is locked up, sometimes its twice a day. When locked up, can not access the device web page, access the internet or obtain an IP address from its DHCP server. Please do a better job on your next release.
Message 8 of 9
kenshap
This has been rock solid for me, no reboots, freezes or drop-outs. Maybe try to reset to factory settings and then re-input your configuration?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 8556 views
  • 0 kudos
  • 7 in conversation
Announcements
