Reply
R8000, VPN and dropping of MD5 signed certificates
Re: R8000, VPN and dropping of MD5 signed certificates
@JamesGL Are we getting any update for the R8000 ?
Message 51 of 88
727guru
Tutor
@JamesGL any updates on this...Certs were dropped in APRIL...
Message 52 of 88
AbhayB
NETGEAR Employee Retired
Hi all,
There's still a slight delay in R8000 to next week due to some P1 bug that was found during testing. So far following hot-fixes have been released:
R6260/R6350/R6850/R7000/R7000P/R6900P/R8000P/R7900P
The way to get them is by downloading the firmware from https://www.netgear.com/support/product/r7000p#hotfix replacing r7000P with specific model number. So for R7000, it's https://www.netgear.com/support/product/r7000#hotfix.
The rest will be released before end of May.
Abhay Bhorkar
Message 53 of 88
Chipicau
Will the update for the r8500 also be release my end of May?
Message 54 of 88
cebailey33
Abhay,
That's excellent news even though I have the R8000 model that has been delayed Smiley Very Happy
I'm looking forward to your update on the status by next week.
Thanks for the reply!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 55 of 88
bossom
Tutor
What about for R6900v2 ?
Model: R6900v2|Nighthawk AC1900 Smart WiFi Router
Message 56 of 88
cebailey33
Hi @AbhayB,
I was reading through the hotfix notes for one of the other routers and didn't see any details about the actual fix.
Would you be able to let me know what algorithm is being used instead of MD5?
And are there any plans to expand the functionality of Netgear's OpenVPN configuration UI to allow for more control?
Thanks!
Message 57 of 88
AbhayB
It's SHA256 from MD5. The UI will have a way to update the certificate if existing.
Abhay Bhorkar
Message 58 of 88
AbhayB
Today we also released firmware for R9000. This is a full ECO.
https://kb.netgear.com/000058270/R9000-Firmware-Version-1-0-4-2
You can use Nighthawk app to update to this version
and also turn auto-firmware update on for receiving future updates automatically.
This firmware also increased Traffic Meter limit to 4095TB!
Abhay Bhorkar
Message 59 of 88
bossom
Tutor
Would there be an update for this for R6900v2 ??
Message 60 of 88
AbhayB
Yes, all products that support OpenVPN client will have a fix rolled out.
Abhay Bhorkar
Message 61 of 88
MrJagu
Guide
When is the update coming out for the R7500v2?
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 62 of 88
cebailey33
@MrJagu
Per Abhay's previous response, by the end of May.
Message 63 of 88
JustSomebody
Tutor
Just a question. I read in this threat taht for the R7000 the version 30 firmware Beta was released.
When i logon to my router and do a check to see if there is an update it tells me that there is no update. I can download and install the beta firmware but i don't like beta software on production machines.
Will there be an official update that can be found via the updater (or the genie app) before the openVPN stops working?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 64 of 88
AbhayB
Hi,
The hotfix releases will be released as official releases soon but do note that they are not 'beta' releases. They have gone through expedited QA process internally before release just not extended testing that's required before we make it official.
Abhay Bhorkar
Message 65 of 88
shamarin
Virtuoso
@AbhayB Whats with russian string table update for R7000? Now with 1.0.9.30 string table for Russian language is old and page with updating sertificate for OpenVPN is not usable (text and button text are not showing).
Message 66 of 88
AbhayB
I will find out from engineering and let you know. This should be easier update.
Abhay Bhorkar
Message 67 of 88
AbhayB
@cebailey33 wrote:
Abhay,
https://kb.netgear.com/000058796/R8000-Firmware-Version-1-0-4-18 has now been posted for R8000. Appreciate the patience.
Best way to update to the latest firmware is to use the Nighthawk app or router UI.
Abhay Bhorkar
Message 68 of 88
cebailey33
@AbhayB wrote:
@cebailey33 wrote:
Abhay,
Woo, thanks a bunch for the reply!
Message 69 of 88
shamarin
Virtuoso
Yes, i know this. I just let you know that new gui language file is not available via server update as usual for Russian language (now it's from 1.0.9.26 version) . On English it's new.
Message 70 of 88
AbhayB
Message 71 of 88
727guru
Tutor
R8000?
Message 72 of 88
AbhayB
Just a few messages above - posted two days ago:
Abhay Bhorkar
Message 73 of 88
shamarin
Virtuoso
What's about R7000 Russian language string table version 1.0.9.30?
Message 74 of 88
Updated my R8000 to this new firmware, but now the OpenVPN service no longer works. Created another thread to discuss.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000-Firmware-V1-0-4-18-OpenVPN-not-working...
Message 75 of 88
Top Contributors
Discussion stats
Announcements
Orbi WiFi 6E
