Reply
R8000, VPN and dropping of MD5 signed certificates
shamarin
Virtuoso
Re: R8000, VPN and dropping of MD5 signed certificates
Did you update openvpn sertificate?
Message 76 of 88
JustSomebody
Tutor
So, end of may. My web interface sees a new firmware version. So i updated and now i have version V1.0.9.28_10.2.32 . . . still only MD5 and no better encryption.
To bad
Message 77 of 88
schumaku
Guru
You are still posting in a wrong thread - this is about the subject "R8000, VPN and dropping of MD5 signed certificates". According to the V1.0.9.28_10.2.32 and your earlier posts, you have an R7000. And here - in Netgear terms (not mine) - the R7000 Firmware Version 1.0.9.28 from the early days of March or early April 2018 is about current (and the last one in the live update). When you consult the R7000 Support page you can find the R7000 Firmware Version 1,0.9.30 Hot Fix which does inherit the change from the MD5 to the SHA256 signed certificates (not only) for OpenVPN. There might be some issues with the language/translation and the UI might not be OK ie. in Russian. No idea on how long it will take before the hot fix version will become standard, the text issues fixed, and a version supporting SHA256 signed certificates will become available in the live update, for the R7000 (or almost any other model....).
Message 78 of 88
JustSomebody
Tutor
You are totally correct. Completely my mistake. Just decided to install the version 30 from the beta link. Normally I hesitate to install it like that but I do want the vpn working without an error.
So it looks like it works now.
Message 79 of 88
jweatherly74
Guide
@AbhayB since this update I am having massive issues with disconnects and cannot connect to many of my games that I play. I never had any issues before this update. Is there a log I can send you that can be reviewed?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 80 of 88
AbhayB
NETGEAR Employee Retired
Hi all,
I would like to summarize so far:
  • FW still pending :
    • target early next week: XR500/R6700v2/R6900v2/R6800. The test is finished just wrapping up the process
    • late next week: DSL Gateways, Orbi, R6900, R7900
  • Official FW posted: R6400v1, R6400v2, R9000, R8900, R6260, R6350, R6850,R7800, R8000P, R7900P, R8500, R6220, R6230
  • Hot fix: R7000, R7000P, R6900P Official releases target is mid-June
Abhay Bhorkar
Message 81 of 88
MrJagu
Guide
What about 7500v2?
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 82 of 88
cbc19
Is the R8300 going to be added to the list of routers to do?
Message 83 of 88
AbhayB
R8300 is released already.
R7500v2 is planned before end of this month.
Abhay Bhorkar
Message 84 of 88
MrJagu
Guide
Thanks
Message 85 of 88
radwolf76
@AbhayB what is the status of the update for the R7500v2? Your last comment in this thread said that it was "planned before the end of [June 2018]", but that date has already passed.
Message 86 of 88
jonath_duc
How to configure the R7500v2? I have tried many attemps without success
My website is ready...
Message 87 of 88
Blanca_O
NETGEAR Moderator
Hi jonath_duc,
What are you trying to configure?
Blanca
Community Team
Message 88 of 88
Top Contributors
Discussion stats
Announcements
Orbi WiFi 6E
