Orbi WiFi 7 RBE973
Reply
R8000 WPA-key for HP6400 printer network setup
vdotmatrix
Guide
I updated the firmware on our router. It changed all the names of the 3 channels and now I have to re-add all the home devices to the home network.
the last one is the HP j6400 series printer that has worked for years.
While re-setting it up it wants the wpa-key.
i thought it would be the password. HOPE
what is the WPA-key and where do I find it?
its not the MAC address is it?
THANKS in advance
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Accepted Solutions
Re: R8000 WPA-key for HP6400 printer network setup
Greetings,
This is the pasword for your wireless network.
Note: The firmware on some older HP printers does not support WPA/WPA2-PSK [AES] and only supports WPA Security [TKIP].
Message 3 of 5
All Replies
vdotmatrix
Guide
BUMP
Message 2 of 5
Greetings,
Message 3 of 5
vdotmatrix
Guide
OKAY!!!
The combination has worked since we got the printer a couple years ago and only when I updated the routers firmware did the issue begin...THANK YOU FOR RESPONDING...I will try again.
Message 4 of 5
Let us know how you make out.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1278 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
