- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 — WiFi Region greyed out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone managed to overcome the WiFi region when its greyed out? as I think its pretty poor on Netgears behalf to limit this function and disable it, seeing as they sell there products worldwide I'd have thought in this day and age when people move/emigrate from one country to another you should be able to change regions to accomodate or do Netgear expect you buy another? as after buying Netgear routers since the early 90's maybe its time to look at other products as I find this a pretty poor show
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 — WiFi Region greyed out
I assume that you bought your router in the USA. You won't see that in devices sold in other countries.
It seems to be down to the law in the USA. There's not much that Netgear can do if the FCC sets the rules.
There are ways to unblock that, but they are not for the faint hearted.
Search - NETGEAR Communities – burnsku
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can revert to an earlier firmware to solve this issue.
I have the same problem being an expat in China.
After you revert do a signal strength test in different rooms with an App and a laptop and see which country has the strongest signal.
I found USA usually has the best and a few other countries might match this as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How would that work?
- Flash old firmware
- Change region
- Update firmware
If you do that, does the region stick and stay "greyed out"?
Remember, tare laws about these things, which is why Netgear creates those settings. I wouldn't want the Chinese police banging on my door because I had an alien wifi channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Bernard
can you give me any help on which version would do it and where to get it from as all the ones on the Netgear site seem to continue to lock it out also the router was purchased in HK
Steve
