Orbi WiFi 7 RBE973
Reply
R8000 - Won't broadcast SSID & won't allow login when hardwired
TheOtherMatt
I have an R8000 that seems bricked, hoping someone has insight to help.
R8000 unit:
Has white lights for everything except the Internet
Won't broadcast SSID for either 2.4 or 5Ghz channels
Won't allow me to login when hardwired via 192.168.1.1
Won't allow me to login when hardwired to www.routerlogin.net or .com
(When I say won't allow login, I mean I get an error saying "The page cannot be reached". There is no option to enter username or password)
I have tried:
Toggling the WiFi On/Off button
Power Cycle
Reset button 10 seconds
Reset button 30 seconds
Reset button during power cycle
Looping ethernet from Internet port to LAN ports 1 through 4 and power cycling. No change in Internet light.
I'm using OS X 10.11 and Chrome for a web browser.
I have a Netgear WNDR4500 that I plugged in and worked fine immediately. Allows log in through wi-fi or hardwire.
Any ideas on next steps to salvage the R8000?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 11
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: R8000 - Won't broadcast SSID & won't allow login when hardwired
If you have tried looping and didn't get any light then it's considered a faulty router.
Message 6 of 11
All Replies
ElaineM
It appears to be your router is faulty.
If you're within hardware warranty, I suggest that you contact support to get a replacement.
Is my NETGEAR product under warranty?
How can I get a Return Material Authorization?
Message 2 of 11
JhayAr
My R7000 is doing the same thing this morning. I've done 5 resets but I still cannot go to the routerlogin.
Message 3 of 11
ElaineM
@JhayAr No Internet light? Did you try looping the ethernet cable? If there's no Internet light then get a replacement.
Message 4 of 11
JhayAr
Yes there is no Internet light after it reboots. But the all the lights work while resetting. My Internet works when I plugged the cable directly to my computer but somehow my R7000 doesn't recognize it.
Message 5 of 11
ElaineM
Message 6 of 11
TheOtherMatt
Thanks @ElaineM
I figured as much but wanted confirmation.
Not even a year old and bricked. Can't say I'm all too pleased with Netgear at the moment.
Message 7 of 11
ElaineM
If it's within the warranty, contact support to get a replacement.
Message 8 of 11
TheOtherMatt
It's my father-in-laws, and he didn't keep the reciept.
Dug his own ditch there, but you'd still expect better for the price of the hardware.
If I don't have proof of reciept or an actual purchase date I'm assuming there's no hope for a replacement unit. Some punk in a big box store convinced him he needed the latest and greatest, when my FIL would have been fine with a baseline unit. The latest and greatest failing is just salt in the wound.
Message 9 of 11
ElaineM
PM me the Serial Number and I will check it on my end.
Message 10 of 11
TheOtherMatt
Just sent, thank you
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3581 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
