Reply
R8000 X6 Nighthawk reset due to firmware
Nlogan1977
Initiate
Had something funny happen and I cannot find anything that says this would be caused my router to reset to factory settings. I updated the routers firm ware and the router rebooted and went back to factory settings. I update the firm ware using the phone app. After the update I had to reinstall all my settings, has this happened to anyone else?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Guru
Re: R8000 X6 Nighthawk reset due to firmware
Yes it has happened to others. Some have even had it happen when they reboot the R8000.
Are your settings being retained now?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
Nlogan1977
Initiate
It seems to be so far
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 315 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
