Reply
R8000 & Comcast SMTP.comcast.net
Retired_Member
Not applicable
If your ISP is Comcast, your e-mail Log option Will Not Work using SMTP.comcast.net
This is a verified problem with .90 and all previous versions.
Message 1 of 9
jmizoguchi
Virtuoso
Re: R8000 & Comcast SMTP.comcast.net
What is the reason for outcome. server address or ports?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 9
Retired_Member
Not applicable
While trying to add SSL something was missed from what I understand. They have a fix which I verified. Now the waiting game until it's added to a future release. Hey Moe, Hey Larry, Hey Cheese
Message 3 of 9
jmizoguchi
Virtuoso
Glitch as usually in firmware ... life of new products Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 9
ravenwolfe
Novice
What exactly is the issue or what are you seeing? I have an R8000 with firmware 10.0.0.74_1.0.31 and no issues with Comcast email. It logs in and send via smtp.comast.net without any problems.
Message 5 of 9
ravenwolfe
Novice
What issue are you seeing? I'm on firmware 1.0.0.74_1.0.31 and have no issues with logging in or my emails sending out of smtp.comcast.net
Message 6 of 9
Retired_Member
Not applicable
The router can send a log via e-mail. Have you tried that option?
Message 7 of 9
ravenwolfe
Novice
I was just setting that up and see the problem you are talking about.
Message 8 of 9
Fairytail
Virtuoso
What port you used for comcast SMTP on email logs feature?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 8503 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
