Reply
R8000 & wnce4004
fastroads
Guide
R8000 & wnce4004
I currently have 2 4004's in the house 1 for XBOX/PS3 and and the other for my TV, Bluray, Receiver.
The one that is connected to the TV will not connect to the router.
Any ideas?
Message 1 of 3
fastroads
Guide
Re: R8000 & wnce4004
Update:
I decided to use my R7000 as a bridge and it works beautifully! Must be something wrong with one of the 4004's.
Message 2 of 3
mediatrek
Virtuoso
During pre-release beta testing I used the WNCE4004 extensively with the R8000 and never had any real issues on any of the bands.
However, if you have "Smart Connect" enabled on the 5G radios, you may experience delayed connection establishment each time (up to 1 minute, 45 seconds). This has been an issue with other 5G devices (usually none- Broadcom chipped adapters... the WNCE4004 is uses Qualcomm-Atheros chips) as well with "Smart Connect." You just have to disable 5G "Smart Connect" and connect to the 5G radio of your choice.
Also, make sure you are using the latest firmware (v1.0.0.32) for the WNCE4004 and after upgrading to the latest firmware do a hard reset of the unit.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6560 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
