Reply
R8000 appends "_re". To my ssid
WalterM
Ssid = egbc24ghz, r8000 broadcasts this ssid plus an ssid egbc24ghz_re. What does this mean and
why "_re" ???
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
ElaineM
NETGEAR Employee Retired
Re: R8000 appends "_re". To my ssid
Welcome to the community, @WalterM
Do you have a range extender?
Is there another device that extends the signal of your router?
If you're not familiar with it, I suggest that you change the SSID and wireless password of your router.
How do I change my NETGEAR router WiFi password or network name (SSID)?
ElaineM
NETGEAR Community Team
Message 2 of 4
WalterM
Thanks for your reply, ElaineM.  No there are no extenders involved.
Message 3 of 4
ElaineM
Double check your SSID's configured on the router before you reset and configure new SSID's and password.
ElaineM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2796 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
