Reply
R8000 data usage by device-- HOW????
I'm trying this again...somebody marked my question as the "answer" on previous post!
How do I see how much DATA a specific device has used?  I have enabled Dynamic QOS but it just shows me transmission SPEED by device.  This is USELESS information, Netgear!  People want to know how much data is used, not data RATES.
I need to find out which device is using all my monthly internet allowance!
I am on latest r7900 firmware, which I assume is the same as the r8000...
I've seen this question on the forum, but nobody seems to have an answer.  SO is this feature simply MISSING??
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
schumaku
Guru
Re: R8000 data usage by device-- HOW????
Ash on my head - I was wrong, too. Afraid, we're using the Nighthawks on fast Internet connections, mostly with QoS off. It's indeed showing the "current" used bandwidth - but only with QoS on.
@starman2k01 wrote:
How do I see how much DATA a specific device has used? ... SO is this feature simply MISSING??
Yes - there is no data volume counter by device.
Not sure who marked any answer as a solution - I can't.
Message 2 of 4
For the life of me, WHO CARES how fast a particular device is performing.  Cable companies limit total data usage per month, why would a router company NOT give you data on what device is using up data?  I now have 3 dozen device...alexas, roombas, google homes, etc. etc. and have no idea how much data they send/receive.
Netgear wake up!  Do something smart.  Replace the "internet speed by device" column with "total data consumed" per day, week, month.
Message 3 of 4
schumaku
Guru
No idea here, too.
Bean counters.
The short window throughput numbers are probably easy to get from the automatic QoS system. Reliably maintaining per device (MAC address - the IP can change) does certainly create massive overhead. And then, we need this functionality - regardless if QoS is active or not.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1949 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
