Reply
R8000 disconnects
Konkhra
Tutor
R8000 disconnects
I recently started having these random disconnects and have been unable find the solution on here yet, has netgear fixed this? I'm on the newest firmware and it has been factory reset too many times to count. All settings are still factory including passwords so it's not user error.
Message 1 of 11
Retired_Member
Not applicable
Re: R8000 disconnects
do wired devices stay connected
Message 2 of 11
Konkhra
Tutor
No, everything goes out, then comes back on, though most times I need to reset to get WiFi working.
Message 3 of 11
JamesGL
Master
Hi Konkhra,
If you connect your computer wired to the modem, without the router, do you get stable connection?
JamesGL
Community Team
Message 4 of 11
JamesGL
Master
Hi Konkhra,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
Message 5 of 11
KurtisJD
I'm having a similar problem. A week ago it stopped working and so i did a factory reset. Now it works now and again but for the most part it won't let anything connect. My hard wired connection is perfect. I even had my internet provider test it and they said their system says I don't have the Internet plugged into the right port. Which i do, sooo really wierd. I tried contacting netgear but still haven't received a response.
Message 6 of 11
KurtisJD
And when i connect with my computer it says the connection is limited.
Message 7 of 11
Retired_Member
Not applicable
Routers fail everyday even the expensive ones.
If resetting to defaults and or re-installing FW, verifing or changing WAN cable, verifing you're using correct adapter doesn't work then your's has failed.
Message 8 of 11
KurtisJD
Yeah i tried all that. And the problem just happened. No changes to any hardware or anything. Hopefully it still has warrenty. Thanks for the response.
Message 9 of 11
Retired_Member
Not applicable
You're welcome,
go to mynetgear for support if you registered it
Message 10 of 11
Talshiar
Devices currently connecting to the R8000 nighthawk
Samsung S7, Samsung S5, Samsung J7, Samsung Note4
Samsung TV, LG TV, Samsung bluray, Samsung 4k
Western Digitical MyCloud devices: EX2Ultra & EX4100
Linksys WUMC710 bridge
PS4 & Xbox1
4 laptops, 1 desktop, Android TV
Epson artisan 810 printer
Seagate Wireless Plus (HDD)
thats 21 devices and for the longest time i incorrectly assumed it was just the number of devices slaughtering bandwidth.
my 12yo has been having fits over his xbox disconnecting in competitive games (the game bans for 30mins after a disconnect), so i finally found the motivation to search online for a solution.  listed below is everything i found and what i did.
Here is what i did in order (and i did them all before testing to say for certain if any 1 thing resolved the issue)
1) updated firmware to V1.0.3.32_1.1.21
2) disabled MMS
3) disabled WPS (Pin)
4) turned off readyshare
5) turned off mediaserver
6) removed USB
7) identified Upnp traffic from WD mycloud in logs (turned off itunes on that device)
so far, so good...
but if the problem continues i will buy a second wireless router
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2774 views
  • 0 kudos
  • 5 in conversation
Announcements
