UnholyZilla's avatar
UnholyZilla
Follower
Oct 04, 2021
R8000 firewall or proxy issue
Over the last 2 months I have been having massive connectivity issues. I have already had my ISP come out and I'm getting the speeds i pay for. The router wasn't giving me the right speeds and I lost a network altogether. I factory reset my router and redid everything on it. Now I am having issues where my xboxs and pc are telling me there is a firewall or proxy server in place not allowing me to use the device or app. If I continuously refresh or try it, it works. Is there a setting or something that I missed when I set it up this time.
  • Me too, I been having same problem for 2 months now. I installed router firmware update V1.0.4.74. about 2 months ago. The update broke the DNS settings within the router software and I been having all kinds of connectivity issues from that time. For temporary fix if you change your DNS settings from automatic to Primary DNS 8.8.8.8 and Secondary DNS 8.8.4.4 will work a little better but it's not gonna completely fix it just happens less often. Hopefully Netgear fixes this soon, a lot of people having the same problem. I hope this helps you for now.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to do any port forwarding for xbox?
    DarrenM
