New Features and Enhancements:
- Supports IGMP proxy which allows PPPoE packets for BT IPTV.
- Supports Open VPN service for mobile devices.
Bug Fixes:
- Fixes the issue where the 2.4 GHz network security encryption cannot be set to WPA-PSK[TKIP]+WPA2-PSK[AES].
- Fixes the issue where NETGEAR downloader cannot be enabled.
- Fixes the issue where the web browser crashes after executing buffer flow attack scripts.
- Fixes the bypassing authentication on lan.cgi.
Firmware upgrade instructions:
Note: To avoid disconnect issues during the firmware download process, NETGEAR recommends the firmware update be performed on a computer with wired connection.
- Write down all the settings which you changed from the default values, since you may need to reenter them manually.
- Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop. The filename after extracting is R8000-V1.0.3.46_1.1.32.chk
Download Link: http://www.downloads.netgear.com/files/GDC/R8000/R8000-V1.0.3.46_1.1.32.zip
