Reply
R8000 no internet connection when vlan/iptv is turned on
miskelis
Just purchased R8000 for IPTV and faced a problem. When I just enable vlan/iptv in router there is no internet connetion.
This is Telia IPTV which requires VLAN6.
As I saw in other topic (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R9000-no-Internet-with-VLAN-enabled/td-p/133...) I should put 0 next to internet vlan although there is no such option- it required to be minimum value 1. This other topic author has the same internet and iptv provider as I do and has had the same issue. Please provide a solution what should I do to make it work.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
miskelis
Re: R8000 no internet connection when vlan/iptv is turned on
I would be really happy if somebody from netgear would suggest me how should I make it work or should I just buy other manufacturer router instead? How should I setup vlan so that both internet and iptv would work?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 539 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
