- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 not syncing time behind Uverse GigaPower modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
R8000 not syncing time behind Uverse GigaPower modem. There is no manaul way to set the time in router. After reboot Router time goes back to Jan 1, 2015. This makes router bandwith meter and also security / schedule to block servies useless. Router use to work fine behind comcast modem. If I switch R8000 to AP mode from router it sync time fine. Switch back to router mode no time sync. Firwall is off on Uverse modem so it is not that. This is in logs on startup. Looks like a delay of 1 second to connect to internet.
[Internet connected] IP address: xx.xxx.xxx.xxx, Thursday, Jan 01,2015 00:00:22
[Internet disconnected] Thursday, Jan 01,2015 00:00:21
[Initialized, firmware version: V1.0.3.4_1.1.2] Thursday, Jan 01,2015 00:00:18
[DHCP IP: (192.168.1.3)] to MAC address XX:XX:XX:FD:DC:XX, Thursday, Jan 01,2015 00:00:16
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Support gave me V1.0.3.5_20160222_ntp_dgb.chk for R8000. Thanks
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 not syncing time behind Uverse GigaPower modem
If you insist on using the r8000 in router mode YOU need to see what options the Uverse box has... can it be used as a modem or bridged ( bridged Mode) or can it pass public IP to a lan port to then feed the r8000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have U-Verse Gigapower, then you probably have an NVG599. You can use these instructions to put it into "bridge" mode (link). It's really a pseudo-bridge mode called IP Passthrough, but it has the same effect of bypassing NAT on the U-Verse gateway for one designated device, which should be your Netgear router. If you also have U-Verse/DirectTV, then keep your set-top boxes directly connected to the U-Verse gateway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem is 5268AC. Modem allows using DMZ Plus mode which assigns ATT external IP to Netgear router. Just like a passthrough mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yup, it's the same feature with a different name. I believe gateways made by 2Wire also call it DMZ+.
Did you already set up DMZ Plus on your Pace?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There seem to be a couple of threads that suggest that the Pace could be blocking NTP for the DMZ Plus device (here). Also, for 2Wire (here). You can try toggling the Strict UDP Session Control setting on the Pace, though it's not clear whether it will help. This setting should be similar to the Open/Secured NAT setting in WAN Setup on Netgear routers. Read about its relevance to NTP in this article (link). Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried all the option you recomended and on different forums but no luck. Netgear support gave me beta V1.0.5.49_20151208_timesync firmware for R7000 which fixed the issue.
[Time synchronized with NTP server] Thursday, May 05,2016 15:25:28
[Internet connected] IP address: xx.xx.xx.xx, Thursday, May 05,2016 15:25:28
[Internet disconnected] Thursday, May 05,2016 15:25:27
[Initialized, firmware version: V1.0.5.49v1.7] Thursday, May 05,2016 15:25:20
I just switched R8000 to AP and now using R7000 as router till they also come out with fix for R8000 too.
Also if I disable DMZPlus mode R8000 gets the time too in router mode. Definately have to do something with DMZPlus and Netgear setting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Did Netgear support explain the bug?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No explanation at all. Had to sign the NDA to get the firmware so I can't distribute it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi smartloom,
Thank you for the feedback for the beta firmware. Just want to check if you have tried using the beta firmware v1.0.5.62 for R7000. Also for R8000, support will contact you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I did not tried v1.0.5.62 for R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Smartloom,
Thank you for the update. Is your R8000 working already?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi smartloom,
Please tag your post as accepted solution to close this thread.
