Orbi WiFi 7 RBE973
Reply
R8000 time zone
Dilly79
Tutor
R8000 time zone
Since reverting back to .68 firmware I am unable to change the time zone to uk.
Anyone else have this problem?
Message 1 of 6
Guru
Re: R8000 time zone
Is there a reason you downgraded?
did you try factory resetting after downgrading?
Message 2 of 6
Dilly79
Tutor
Re: R8000 time zone
Yes I factory reset and was still the same. I’ve now installed.74 firmware and the time zone is ok now.
My parental controls (circle) don’t seem to work on the latest firmware + my download speeds were slow
Message 3 of 6
Guru
Re: R8000 time zone
Are you selecting the GMT for UK as seen here?
Noticed that if you have Traffic Meter or Circle enabled on the R8000, this seems to slow bandwidth down.
Message 4 of 6
Dilly79
Tutor
Re: R8000 time zone
Yes I did have traffic off. My circle is on
I selected GMT as in the picture
Now my next problem is my circle passcode. It’s not texting me the code, tried loads of times. I have premium
Message 5 of 6
Guru
Re: R8000 time zone
Please post here for any Circle issues:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
There is some info at the top of that forum that may help.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 776 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
