Reply
R8000 v1.0.3.26 - Preliminary Speed testing
SRT10
I'd like to preface this with, I know that this beta release was probably quick to release and that it addressed a serious security flaw so I am glad that was dealt with asap (rather asap after they realized it was identified in August).  That being said, I have observed a very clear 30% drop in speeds since the beta  install and I'm curious if this is a firmware related possibility.  The beta install was done at 3:20am here when everyone in my area is asleep, I'm typically looking at 900+Mbps at that time and +700Mbps at any other time of the day.   It's consistently observing these speeds since install.  I'd like some input by Netgear once they take a peek to see if it's addressable.
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: R8000 v1.0.3.26 - Preliminary Speed testing
Have you tried a factory reset followed by manually reconfiguring your settings?
Message 2 of 6
SRT10
I did a factory reset yes and have tried with no settings changes at all as well.
Message 3 of 6
SRT10
I have noticed the speeds all over the map the more I monitor this.  I think this may be coincidental with ISP related issues as I've been all over the map the last couple of days however that first initial day just happened to be right at the same time as the beta update to my router and seemed just too consistent to be coincidental.  I will chalk this up to ISP related issues.
Message 4 of 6
SRT10
Message 5 of 6
JamesGL
Master
Hi SRT10,
Is the issue resolved now with your ISP?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2544 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
