Reply
R8000 - vb.net open to get getElementByID and "apply"
tinh2ways
Follower
is is the html from the router
WLG_wireless_dual_band_r8000.htm
I want to change the network key every hour automatically by vb.net apps.  Or any kind of app it would be fine.  Your genie does not have that option on the app.
It does not have any "id" so I could capture it.  Is there any way I could change webpage so I could capture and change it?
Thanks,
Ly
Message 1 of 2
JamesGL
Master
Re: R8000 - vb.net open to get getElementByID and "apply"
Hi @tinh2ways,
Welcome to Community!
You can change the network key or password on Genie via manual configuration. It does not have an option generate automatically a different network key. I am not sure if other users has suggestions with the kind of setup you want but for NETGEAR it can only be done manually.
JamesGL
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1892 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
