Orbi WiFi 7 RBE973
Reply
R8000 wifi scheduler not working
Toan
I have a Nighthawk X6 R8000 with Firmware Version: V1.0.3.46_1.1.32
After the recent firmware upgrade the Wifi scheduler no longer works.  Below are the steps I took to troubleshoot the problem:
1.  Reboot router
2.  Went into routerlogin.net site
3.  Under Advanced Setup - Wireless Settings
4.  Put check mark next to -Turn off wireless signal by schedule - added a time window
The router will not disable the wifi regardless of what schedule I put in.  I even went so far as performing a router reset and got the same result.
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 4
Accepted Solutions
JamesGL
Master
Re: R8000 wifi scheduler not working
Hi Toan,
Check the time of the router, make sure it is same as your time. You can check it under schedule.
https://kb.netgear.com/24055/How-do-I-schedule-when-to-block-internet-sites-and-services-on-my-route...
Message 2 of 4
All Replies
JamesGL
Master
Hi Toan,
Message 2 of 4
Toan
It's working correctly after the time zone change as you indicated.
Thanks,
Message 3 of 4
JamesGL
Master
Hi Toan,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3573 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
