Orbi WiFi 7 RBE973
Reply
R8000 won't stop restarting
The1inthemiddle
The router is constantly restarting, gets up and running then crashes. I haven't updated the firmware since the purchase. Tried to reset the router but it will not reset back to factory settings or new from box settings. Can't even login to the admin when using a wired connection without the Internet hooked up. Any help would be greatly appreciated..
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
LeeH
Prodigy
Re: R8000 won't stop restarting
Try a very long reset by pressing in the reset button on the back of the router for about 30 seconds until the power light turns orange and starts to blink three times in a row.  This repeated reset recycling may work for you.
Message 2 of 3
All Replies
LeeH
Prodigy
Message 2 of 3
The1inthemiddle
Thank you that worked but the 30/30/30 did not which is odd. None the less it's working again.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5891 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
