Reply
R8000
JoseNYC
R8000
I keep trying to access a charitable non profit site called: www.MedicalServiceDogs.org and I keep getting blocked by sitelock.
I'm not sure if this a router issue, but any suggestions would help!
Here's the error:
Error code 20
The proxy failed to connect to the web server, due to TCP connection timeout.
http://www.medicalservicedogs.org/
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
myersw
Master
Re: R8000
That would be an issue between you and sitelock. Nothing to do with your Netgear router.
I am running Pi-Hole on a rasberry Pi plus Bitdefender on PC I am anwering this on and can get there fine. No issues for me.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 5
IrvSp
Master
Re: R8000
Get there fine on my R8000...
It indicates (the error) that the TCP/IP connection was forcibly closed, but not by who? You using a VPN?
Message 3 of 5
JoseNYC
Re: R8000
No VPN, but it actually allows me to access the site if I turn my VPN on.
Message 4 of 5
IrvSp
Master
Re: R8000
Interesting. Do you mean turn on the ROUTER setting or enable the VPN on the device? Sure sounds like your problem is VPN related? Possible if you leave the VPN router function on it blocks you or turning it off on the router but not the device causes the problem?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 876 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
