Reply
R8000
ericnix
R8000
Looks like the R8000 is out. A little disappointed that it uses the same 1GHz dual processor.
Netgear R7000
DD-WRT Kong 24345
overclocked to 1.2 GHz
Message 1 of 21
Redtulips7
Apprentice
Re: R8000
It does not need 1Ghz dual core Processor!!!its nothing but marketting hype!!!Its not a PC but a Router so nothing to upset about it!!!As long it work according to it Features then it should be good and newer Device doesn't mean better....
Nighthawk AX12[RAX120]
Nighthawk X10[R9000]
Message 2 of 21
ericnix
Re: R8000
Sorry, I was thinking faster processor = faster routing.
Netgear R7000
DD-WRT Kong 24345
Message 3 of 21
Dalmo
Re: R8000
Message 4 of 21
Dalmo
Re: R8000
Message 5 of 21
gerick
Re: R8000
No trade-up offers? 😞
Message 6 of 21
Re: R8000
Should've purchased at Best Buy and got the Geek Squad protection plan. They let you return it no questions asked for store credit (aka a r8000).
Message 7 of 21
Lexist2112
Luminary
Re: R8000
Thought you guys might want to see this. Found this on the Netgear R8000 test results and legal docsFCC site.
Message 8 of 21
bobcageon
Guide
Re: R8000
Can you guys just imagine that the firmware upgrades to the R7000 this far along are still not rock solid, yet Netgear comes out with another flagship router that surely is destined for the same thing? Do you think the just use the r7000's firmware & run with it? It's not the same router, i can't be that easy, right?
Message 9 of 21
Redtulips7
Apprentice
Re: R8000
As soon the new Router release next future Router Project has began right the way or before!!!!Netgear as well as other Manufacturer never or unable to fix some of the problems or issue with the Products!!!!Wise People wait and see what new Product bringing in Vs other People ready to jump in new Product Wagon!!!!:
:cool::cool::cool::cool::cool:
Message 10 of 21
bobcageon
Guide
Re: R8000
that's why I waited 9 years to replace my dir-655 with this router 6-8 mths after its release lol So my question(s) to the OP is rhetorical I guess. Enjoy dealing with whatever issues may pop up that need fixing if you pursue a router that basically has an added 5g band that is still in its infancy as far as range and stability goes. I'm good with running two R7000's. and it seems the bridge mode issues are fixed with the latest firmware, let alone King & Shibby's work.
Message 11 of 21
Retired_Member
Not applicable
Re: R8000
There's really no use in waiting a few months anymore. Manufacturers in general are turning out new product so fast that 6-8 months might leave you 2 or 3 revisions behind.
You're best bet is to either jump in with both feet at the current point in time and not worry about obsolescence, or go out and buy something REALLY mature, like say an N900 router.
Message 12 of 21
jmizoguchi
Virtuoso
Re: R8000
Only the consumer buys the the latest greatest in some level. Look at all the rest of fortune 500 and retailer business etc . They are definitely are not buy latest great but mature.
One these day I would buy 802.11ac router but I'm quite happy with my Prosescure router and open mesh AP (802.11n). Solid network without failing... 🙂
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 13 of 21
NatRay
Tutor
Re: R8000 - New does not equate to better . . .
My network is populated by some solid performance consumer routers that have not let me down. Recently I purchased three, what I call backup routers, off eBay: Two WNDR3700v1 and a WNDR3400v2, total cost for all three, less than $50.00 including shipping. Combined with backup configuration files, should a failure occur among my active routers I can be up and running within minutes . . .
Best regards,
Nat Ray MCSE/MCT since 1997
_______________________
Cox Communications > SB6120 DOCSIS 3.0 > WNDR3700v1 (4), WNDR3400v2 (2), WPN824v2 (2), R7000, RT-N66R *AP(s) via Wired Backbone* > Ooma Telo / D-Link DGS-1024D > NeoTV-550 (3) . . .** HPEnvy800 -PHX **
DD-WRT v24-SP2 (12/14/11) std. Build 18007
Optimize your network: Disable IPv6 . . . Post responsibly . . .
‘Quality trumps Quantity’
Message 14 of 21
madhatter
Apprentice
I'm on a 3700v1 as we speak. I have it connected to a NETGEAR powerline and use it as an access point for my deck area outdoors. I just installed dd-wrt for fun and it's working really well. I like the virtual access support in dd-wrt. Can't go wrong with the 3700. Great router.
Who did you buy your 3700s from?
1xRBR50 1xRBS50 2xRBS40
Message 15 of 21
NatRay
Tutor
Search eBay for WNDR3700. Bought one for $10.50 . . . In my book that's a great deal 🙂
Installed DD-WRT on everything . . .
Best regards,
Message 16 of 21
madhatter
Apprentice
I did search ebay, but nothing close to 10.50 ... great deal!!
Message 17 of 21
NatRay
Tutor
The key to getting a great deal on eBay is ‘Bidding’ at the last possible second an item is up for auction . . . 😉
Best regards,
Message 18 of 21
jmizoguchi
Virtuoso
Re: R8000
I would also remind you that over 80% of ebay purchasing the router has been a lots of issues for users.
I don't think most seller would not check and double check these used units and seems to have higher failure rate. I know I sell used routers and networking equipment and has not issues but some to think over the hassle of saving some money. 🙂
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 19 of 21
NatRay
Tutor
Re: R8000
You are absolutely right . . . Buying on eBay is a gamble, and you are rolling the dice. But as long as you realize you can lose, and don't wager more than you can afford, eBay can be very rewarding 😉
Best regards,
Message 20 of 21
Redtulips7
Apprentice
Re: R8000
Its out now!!!
Message 21 of 21
Top Contributors
Discussion stats
  • 20 replies
  • 25887 views
  • 0 kudos
  • 11 in conversation
Announcements
Orbi WiFi 6E
