- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000P Loses internet daily
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have only had it for a few weeks and it needs to be restarted almost daily. It works just fine, then for some unknown reason it losses internet. It is up to date with Firmware Version
V1.4.1.50_1.3.10
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jlipkowski wrote:It is connected to a Spectrum E31T2V1 cable modem. Will that impact the solution you offered?
Its checking to make sure you're not running a double nat which can cause issues.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000P Loses internet daily
What modem is it connected to?
I'd try installing version 1.4.1.62 of the firmware over an ethernet connection, factory reset the router, and then reinstall it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far, so good. I did have to restart it one time, but other than that it is stable.
I do have two other routers connected at Access Points, is there any way they could cause an issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
it shouldn't cause an issue but I won't rule out anything. If the drops start happening again, you can always shut them off for a period and see what happens.
