Reply
R8000P Losing WiFi SSID after power cycle
mhampson
Follower
After having issues with Spectrum (formerly Time Warner, both suck) internet and not able to connect to the internet, I had to power cycle both my modem and router. But with this router as I have many other Netgear routers, I lost all of my SSID info and my Guest network turns it self back on as I had performed a partial reset which I did not!
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 2
schumaku
Guru
Re: R8000P Losing WiFi SSID after power cycle
Factory reset (not before you have ensured you have all ISP data required in case at hand), reconfigure from scratch, and re-test a power-failure situation.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 369 views
  • 0 kudos
  • 2 in conversation
Announcements
