Reply
R8000P Nighthawk ( How do you switch bandwidth on your devices being supported by this router?
SeanVS21
Follower
How can I switch my PlayStation 4 from 2.4 GHz to 5GHz, and my cell phone from 5 GHz to 2.4 GHz?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Guru
Re: R8000P Nighthawk ( How do you switch bandwidth on your devices being supported by this router?
Are you using smart connect? If so, it dynamically moves devices between bands.
if you want to assign them yourself, just disable smart connect and name the bands different.
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 141 views
  • 0 kudos
  • 2 in conversation
Announcements
