Orbi WiFi 7 RBE973
Reply
R8000P — Nighthawk X6S Firmware Wont Update
redmarkred
Initiate
The firware wont update on this router. Have tried using the updte on the routerlogin.net page and also by manually uploading the firmware file but no matter what I do the version number remains the same (V1.4.1.50_1.3.10)
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Sparker5016
Guide
Re: R8000P — Nighthawk X6S Firmware Wont Update
Greetings.  This is a known problem it really has nothing to do with you.  Unfortunately you will have to play the "Support Game".  They hold all the cards, just submit, and provide them with any info they want.  It's a shame that so many people are ready to write off Netgear because of a firmware update.  I will match my Nighthawk R8000P performance wise with ANY router out there presently.  I had the same firmware issue that everyone else had, bite the bullet and play the game.  Resistance is futile. LOL.  I'm running 85 online devices flawlessly.  I am totally satisfied with Netgear.  Their support leaves a lot to be desired but then again too, you just can't give out an unlimited supply of $300 routers.  Good luck to you, and remember, just play the game.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 521 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
