Reply
Highlighted
Follower
R8000P Randomly Changing Network Names
All I did was unplug my router and plug it back in, and my WiFI SSID's were all changed to Netgear when it booted back up. Why is the router automatically re-naming my wirless networks and removing any security I had in place?
Photos Attached.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Highlighted
Guru
Re: R8000P Randomly Changing Network Names
which version of the firmware are you on?
One version had issues with that happening on reboot. You can try upgrading/downgrading to fix it.
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 62 views
  • 0 kudos
  • 2 in conversation
Announcements
