Reply
Highlighted
R8000P VLAN setup
Is is possible to set up VLAN's on a home network using this router? All I can find in the directions is stuff about VLAN/IPTV, and I am not sure what IPTV is or if this will solve my problem. I have my network at home, plus I am setting up a domain for personal use, and I want to separate the two. Is this possible?
Thanks,
Charles Nailen
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 3
Highlighted
Re: R8000P VLAN setup
Hi Charles,
IPTV..  Internet protocol television.  Google for more info.
The R8000P does support wired or wireless vLAN tag grouping.  Introducing a smart switch with layer3 protocol support may provide additional capability.  However, I'm not completely clear whar you are trying to accomplish.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.64 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 3
Highlighted
I have my normal home network which contains my TV's, phones, tablets, etc. that connects to my ISP. I have a separate domain which I also want to attach to my ISP, but be able to have separate DNS, DCHP, etc. on the domain. Hope that makes it a little clearer.
Chuck Nailen
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1102 views
  • 0 kudos
  • 2 in conversation
Announcements
