jlundgaard_dk's avatar
Jan 18, 2022
R8000P and R8000
I use both routers and i have one Nighthawk android app.
I can not administer both routhers without changen the app every time.
Is there an app that can administer two routers at the same time?
Regards Jens
1 Reply
  • FURRYe38's avatar
    No. You can only connect to one router at a time thus you have to switch to the other router prior to opening the app.
