Reply
R8000P losing internet
Sthshrmags
Router is 6 mos old and is losing connection to internet both wifi and wired. I have factory reset and it worked for 20 min. I have rebooted sevwral times with the same result. I am on the latest update. The led lights are lit correctly. Our devices connect to it but "with problems" which is that there is no internet. I have read all the conversations about this same issue but there are no solutions. What else could be causing this?
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: R8000P losing internet
What modem are you connecting the router too? Does that modem have a built in router?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 400 views
  • 0 kudos
  • 2 in conversation
Announcements
