Reply
R800P Fraggle Attacks
JukeDuke
Follower
Hello, I need help on solving this issue, my wifi been pretty laggy for two months now and a couple weeks ago i decided to check my router logs when I see "DOS Attack Fraggle Attack" all over it.
[DoS attack: Fraggle Attack] from source 10.240.161.1,port 67 Monday, Oct 19,2020 07:04:12
[DoS attack: Fraggle Attack] from source 10.240.161.1,port 67 Monday, Oct 19,2020 07:00:34
[DoS attack: Fraggle Attack] from source 10.240.161.1,port 67 Monday, Oct 19,2020 07:00:10
[DoS attack: Fraggle Attack] from source 10.240.161.1,port 67 Monday, Oct 19,2020 06:58:22
[DoS attack: Fraggle Attack] from source 10.240.161.1,port 67 Monday, Oct 19,2020 06:55:06
[admin login] from source 192.168.1.9, Monday, Oct 19,2020 06:54:14
Is this cause for concern and is there any way to fix this
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: R800P Fraggle Attacks
You may want to check if dos protection is enabled on the router.
https://kb.netgear.com/19957/What-does-Disable-Port-Scan-and-DoS-Protection-do
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 348 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
