Reply
R8500 Enable LAN/WAN Packet Capture
andersonoz
Hi all.  I'm trying to educate myself about my netgear router, what would the option Enable LAN/WAN Packet Capture" on the 192.168.1.1/debug.htm page do for me?  Will it actually capture all packets to a text file, in more detail say than the router logs?
Message 1 of 4
samulel
Guide
Re: R8500 Enable LAN/WAN Packet Capture
Yes, It gives you the detail Information of LAN/WAN packet Transfer and you can see the complete history more than router logs.
Message 2 of 4
andersonoz
Thank you for your help.  Once I click 'start capture' let it run for a while, generate some data, then click 'save debug log' a file is downloaded containing a few text files like below
router_config
Console-log1.txt
udhcpd_log.txt
udhcpd.leases
do you know what each of the files shows?
Message 3 of 4
samulel
Guide
The router_config, udhcpd.leases file format will be different.
Console-log1.txt - It contains detail Informations about the router real time activity, services, session connectivity, filesystem etc
udhcpd.leases - Udhcp is a small dhcp server on the router, the file contains the service status of (server & Client) and gives the lease time Information for the Ip obtained on the WAN port.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1758 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
