Orbi WiFi 7 RBE973
Reply
R8500 Log Files Not Clearing
RealDogfart
Guide
I've setup daily log file emails.  After receiving the message I usually check the log and then clear it.  The next day I get the same log file.  I've tried clearing, refresshing and applying but I still get the log file daily... for the most part.  Sometimes it actually gets cleared.  What's going on?
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 14
Accepted Solutions
RealDogfart
Guide
Re: R8500 Log Files Not Clearing
See what happens when you wait long enough? Firmware V1.0.2.86_1.0.75 was issued. The release notes are not specific: "Bug Fixes: Improved security protection on device web server." So whether the update actually fixed the problem or the firmware being flushed and refreshed the issue appears to have been resolved. After the update a cleared the log and viola, the log file actually cleared. If I notice any more issues I'll come back and make comments but I consider this issue resolved. Thanks.
Message 13 of 14
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @RealDogfart
What kind of log files?
Are you saying that the log files are the same time and date or same logs with different time and date?
Can you post a screenshot?
Message 2 of 14
RealDogfart
Guide
I don't know what kind of log files. I'm not sure where the router stores it's logs or whether I have access to them. What I'm referring to is under the Advanced Tab/Administration/Logs. Secondly, under Advanced/Security/Email I've checked 'Turn E-mail Notification On' And, at the bottom of the page I've setup 'Send logs according to this schedule' DAILY. I'd love to paste a screen shot but that's not an option in this messaging system.
Message 3 of 14
ElaineM
That's right, those are the log files. That's the only place to see the logs.
Are you getting the same logs everyday with the same date and time?
You may post your screenshot by clicking the image icon.
Message 4 of 14
RealDogfart
Guide
Interesting... the icon is grayed out but it still works.
So my issue is that even when I refresh, clear or apply the log, I get the same one daily.  It's not clearing the log. To be honest, I havent tracked how long I get them but it could be for 7 days.  Each day they are identical
Message 5 of 14
ElaineM
Did you try to reflash the firmware of the router?
If you have the latest firmware, re-upload the latest firmware then do a factory reset then reconfigure the router.
Message 6 of 14
RealDogfart
Guide
Well I have to say that reflashing my firmware would not be my first thought. If that is what you are recommending then I'll try it. I'll of course backup all of my current settings first.
Message 7 of 14
ElaineM
Feel free to give us an update once you have tested it.
Message 8 of 14
RealDogfart
Guide
Question: Does the factory reset also revert the firmware to the shipped version? Or does it leave the firmware intact and reset everything to the factory default settings? I'll give it a try later on when things get quiet.
Message 9 of 14
ElaineM
It will just restore the settings to factory default.
It  will not revert the firmware.
Message 10 of 14
RealDogfart
Guide
No update.. I haven't had time to work on the router yet. Will try soon.
Message 11 of 14
ElaineM
No problem. Feel free to provide us your feedback once you have tried it.
Message 12 of 14
RealDogfart
Guide
Message 13 of 14
ElaineM
Glad to hear that it's resolved!
Thank you for the update too.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3830 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
