Reply
R8500 Nighthawk won't update firmware in the app
AprilA
Initiate
The nighthawk app says there's a firmware update but Everytime I try to install it, I get a error message. What can I do?
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
Re: R8500 Nighthawk won't update firmware in the app
Start by telling us the error message and what you are doing to get it.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
AprilA
Initiate
Hi! Thanks for reaching out! Well, I went to the Nighthawk app, and saw that it had a update, and when I attempt to install it, it loads for about 2-5 minutes and then says update failed. I took a screenshot of the error message in case it could help you! I greatly appreciate your help with this!!
Message 3 of 4
Ah. The dreaded Nighthawk App. You have my sympathy.
Experienced users try to avoid it. The best way to update the firmware is with a browser and a wired LAN connection to the router.
There is a support for the R8500, including a manual and firmware, somewhere at the end of this link:
>>> R8500 | Product | Support | NETGEAR <<<
See the section Update the Router Firmware.
The release notes for the newest firmware explain the most reliable, and safest, approach.
R8500 Firmware Version 1.0.2.130 | Answer | NETGEAR Support
Just another user.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2134 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
