Orbi WiFi 7 RBE973
Reply
R8500 - Turn off wireless signal by schedule does not work
Arepaking
Hi!
My "Turn off wireless signal by schedule" setting is not being saved.
I created a period, then checked the "Turn off wireless signal by schedule" setting, click saved. The router goes into "applying settings mode", I noticed the wireless signals goes off for some seconds, then signal comes back. I then go to check the Wiresless Settigns again and I keep noticing the "Turn off wireless signal by schedule" is kept unchecked.
Is someone else experiencing this issue?
I am running the latest firmware: V 1.0.2.26_1.0.41
Message 1 of 20
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: R8500 - Turn off wireless signal by schedule does not work
@Arepaking Our engineering team is aware of it.
I'll give you an update once I hear from them.
Thank you for being a loyal NETGEAR customer!
Message 9 of 20
All Replies
Retired_Member
Not applicable
are you using smart connect
Message 2 of 20
Arepaking
Yes I am using Smart Connect.
Message 3 of 20
Retired_Member
Not applicable
I'm thinking that could be the problem, because they work together and it's not smart enough to reassign attached clients to another band
Message 4 of 20
Arepaking
I think you are right. However, NetGear is advertising SmartConnect as a feature where the router will determine the best 5Ghz signal for each connected device. It should not really matter if the Signal is turned off as each device will be establishing a new connection therefore.
It would be the same as this scenario:
a) Enable SmartConnect
b) Connect your Wifi devices
c) Manually press the Wifi button on the R8500 to turn off all radio frequencies (2.4 and 5)
d) Press the Wifi Button again on the R8500 and the signals will turn on.
e) All devices are connected again.
I am hoping a NetGear staff can read my post and chime in their thoughts. Hopefully this will be something that could be solved via a firmware update.
Message 5 of 20
Retired_Member
Not applicable
I only answered the question and don't have that router, I do have several others with smart connect and I don't care for it.
Smart connect requires the SSID's to be the same and same security so one could assume it also requires the radios to be On for it to work correctly.
Pressing the Wifi button is a mechanical action and turns all radios off while scheduling is software driven so it's not the same. Imagine if a user was using A VPN connecting to work from home. The timed event would break that connection while trying to re-establish another and drop the vpn connection.
Good Luck!
You're welcome,
Message 6 of 20
Arepaking
Thank you Searay! Smiley Happy
Message 7 of 20
Retired_Member
Not applicable
You're Welcome!
Message 8 of 20
ElaineM
Message 9 of 20
captblaze
Tutor
this feature hasnt worked since the product shipped. $400 router with a problem like that? great engineering team, wouldnt ya say?
and while i am on this topic....
the implementation of this feature is all wrong. instead of shutting an entire radio  down, you should be able to target individual clients to shut down on a schedule. this way i have finer control of the feature instead of an on / off switch
Message 10 of 20
ElaineM
@Arepaking The support team is waiting for your response.
@captblaze I apologize for any inconvenience this may have caused you. Kindly register your device and let me know once done so I could forward your information to the support group.
Thank you!
Message 11 of 20
Arepaking
Thanks Elaine.. I will reply soon.
Message 12 of 20
ElaineM
@Arepaking You're welcome. Just reply at your earliest convenience.
Message 13 of 20
martyr444
Apprentice
Hello, has this been resolved yet because it's not working on my R8500 with the latest firmware V1.0.2.26_1.0.41
Message 14 of 20
Arepaking
Hi!
Neatgear support sent me a newer firmware version which corrected the issue. I'm assuming they will make this firmware public in the near future.
Message 15 of 20
chascent
Luminary
Can you share the firmware? CC
Message 16 of 20
Arepaking
I wish I could but I had to sign some legal forms to obtain the non-public firmware to help the team to confirm it got solved. I believe it prevents me from distributing. Maybe a NetGear rep could provide an update about when it will be released?
Message 17 of 20
ElaineM
For those who are interested, make sure you have registered your device and PM me your details.
Thanks!
Message 18 of 20
chascent
Luminary
done message sent
CC
Message 19 of 20
captblaze
Tutor
@Arepaking - did the fix make it so at the scheduled time the designated radio turns off, or do all radios recycle then the designated radio turns off? my r8000 would momentarily recycle all radios and when the cycle completed the designated radio turned off.
that to me is a poor implementation and should not be at the radio level, it should be at the client level so you arent interrupting all clients, just the ones you designate.
there shouldnt be that recycle of all radios either, other router brands have time scheduling that either affects a specific client or radio, but not all radios
Message 20 of 20
Top Contributors
Discussion stats
  • 19 replies
  • 5398 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi WiFi 7
