Reply
R8500 bricked after attemted firmware upgrade
Stantona
Windows 10,R8500 Nighthawk X8.
Tried to do a firmware update. Now cannot get into router. Tried to reset but still no luck. I have tried all the suggestions that can find. It should be a matter of software. What is the latest suggestions on getting this up and running? Worked great for about 13 months. Then I got an email from Netgear to upgrade the firmware. Big mistake. Now I would like to get any firmware to work.
A direct line to the router from the computer allows me to see the router but when I tried to use the tftp2 I never get the 'green' light. The little window says it cannot find the router. Any suggestions? Thanks for any help.
Alex
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 6
Re: R8500 bricked after attemted firmware upgrade
What does the power LED on the router look like?
Have you tried the "paperclip" factory reset?
If you have to use TFTP, it might be easier to use the Windows built-in TFTP client.
I assume that you have read the tftp instructions, you don't say.
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
  • Control Panel
  • Programs and Features
  • Turn Windows features on or off
  • TFTP client - enable
That's probably easier than retrieving software from a website.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 6
Stantona
The power light is solid amber after turning on the router.
After a minute or so, it turns solid white.
If I do the tftp2.exe procedure, the power light never turns green. It starts the amber/white cycle all over again and repeats this continuously. So I never get a chance to use the tftp2 to try to upload the firmware.
I think the reset worked because the admin/password are back as the default values with which it came.
I have nothing connected to the computer but the router using number one ethernet port, not the yellow Internet port.
Have I left out anything?
Thanks,
Message 3 of 6
antinode
Guru
> [...] A direct line to the router from the computer allows me to see
> the router [...]
   What does that mean?  "see" how, exactly?
> has a TFTP function built in, [...]
   Its LED colors are not very current, either.
> [...] If I do the tftp2.exe procedure, the power light never turns
> green. [...]
   I, too, would try the command-line TFTP client.  It would also be
nice to know if you did the whole static-IP-address configuration on the
Windows system (with details), and if you tried a test like:
      ping 192.168.1.1
   How, exactly, did you determine this?
   Nothing connected to the router except the computer?
Message 4 of 6
Let's stick to one discussion here.
How to install firmware - NETGEAR Communities
Duplicated questions won't get you better answers.
Just another user.
Message 5 of 6
michaelkm8
I found a way to at least get the router back online with earlier firmware.  If you look at my post it's a start.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3182 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
