- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8500 how to unlock wifi region
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've just unlocked a R8500 bought in US and now working in EU. You know that all the router wifi that are selled in US market have wifi region locked to United States or North America, but I've found a solution putting togheter ideas from community. You should connect not in wifi but wired to your router and for me have worked and if you try is at your risk if you are not sure stop youself.
Step 1:
You should enable Telnet on your R8500 and the solution is http://routerlogin.net/debug and you check as active the Telnet check box.
Step 2:
On you computer you have Telnet active, on Linux is by default on Windows 10 it's an add-on that you can activate from app / program installation
Step 3:
Assume you are now on Win10/8/7 you should activate command window with CMD
Step 4:
Activate at prompt the Telnet
Step 5:
The first Telnet command is "open" "IP address" of your R8500 and user and password as usual I've not tried routerlogin.net but I suppose that is working
Step 6:
at prompt command "burnsku" to check the actual configuration that should be "0x0001"
Step 7:
at prompt command "burnsku 0x0002" and you unlock the wifi region selection, you should give the "burnsku" to check the upadte a 0x0002
Step 8:
Restart your R8500 and your Wifi region is now unlocked and you can choose your location.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's true ...you can use Telnet on WiFi but is safer to use a wired connection, by Telnet you can change many parameters and brick your router and the only way to recover your router is to use TFTP in a wired way.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8500 how to unlock wifi region
> [...] You should connect not in wifi but wired to your router [...]
Why? Does it actually matter?
> box.
Many router models don't have a "Telnet check box", but various
"Netgear Telnet Enable" programs are available on the 'net. (I use the
program which I modified, http://antinode.info/nte .)
> Step 4:
> Step 5:
> is working
Save a step: telnet <address_or_name>
- Mark as New
- Bookmark
- Subscribe
- Permalink
