- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8500 settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the router is somewhat new to me, I have few setup questions. FW_v1.0.2.116
1) In a log [Time synchronized with NTP server] states updated every 2 hours to the second. I think this is rather frequent and I do not see any adjustment.
2) No lease time, which I find odd. Most of the pheripherial have reserved address in my setup, but for Guest Network, I would like to have some control.
3) Login time, way too short for the novice like me with a new router.
Otherwise one great router so far.
Cheers everyone.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is nothing you can do for all 3 items you pointed out. NTP on NG routers is not configurable, same for DHCP lease time through GUI and login timeout. For lease time, you can enable Telnet and modify the /tmp/udhcpd.conf file then restart the service (I have this: option lease 7200 which gives a 2 hours lease to my devices)
There are Idea Proposals on this community forums but no idea if and when NG will pick those up, not to mention make them configurable
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8500 settings
Hmm… I see.
If one is the best from mediocre, there is not much incentive to improve.
