Reply
R8500 very slow connecting through Virgin Media
Snajix
Hi there,
Recently, anbd I believe with no changes to the network at our end, the wireless and wired connections through our R8500 seem to be really slow.
If I put the Virgin Media Superhub3 into router mode and connect directly to it I get speeds of around 380mbps. When in modem mode and connecting though R8500, speeds drop to 130mbps.
Set up is:
Superhub 3 modem mode
into
R8500
attached to which is
Netgear Orbi
Interestingly, the speeds obtained from teh Orbi kit (wireless connections to them) are in excess of 350mbps.
Any thoughts?
Regards
Sanj
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 3
DarrenM
NETGEAR Moderator
Re: R8500 very slow connecting through Virgin Media
Have you done any firmware updates?
Darrenm
Message 2 of 3
Snajix
Hi there,
Yes I have checked that I am on the latest firmware. Seems fairly unstable at the moment. Several Windows machines are all reporting between 150-280mbps while iPhone reports over 380mbps consistently.
Also, speed testing the internet port of the router through the Nighthawk app or from the web page for the router on a windows machine both report 380mbps consistently.
Am a bit stumped. Orbis connected to the router report 380mbps via Windows devices.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 396 views
  • 0 kudos
  • 2 in conversation
Announcements
