- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R9000 5GHz visible but cannot connect. 2.6 band is fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had XBox S and new Samsung UHD 65 connected via 5GHz and had worked fine until a month ago. My Samsung Note5 gets an "authentication error" and fails to connect as well.
The R9000 has the latest firmware and has been rebooted several times.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to factory reset the router and see if that will help.
Resetting will wipe out all the settings of the router, so you will need reconfigure it after.
You may want to use backup and restore feature for easy reconfiguration.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R9000 5GHz visible but cannot connect. 2.6 band is fine
Have you tried changing the wireless channel?
Will you experience the problem if you downgrade the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know what/how "changing wireless channel" means.
I had problem before I installed latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I figured out how to change the channel-no luck. None of my various devices will connect to the VISIBLE 5GHz band.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset fixed it. May have been due to 5GHz band being set to wrong security type-just let everything set at default and all bands performing well and all accessible.
