- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R9000 5Ghz Radio not enabled although LED showing enabled. 5Ghz Radio not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R9000 has the latest firmware (V1.0.2.40), but 5GHz radio not functioning. The 5GHz radio is enabled within the Wireless Settings menu, with SSID enabled and no schedule, but 5GHz signal does not appear available. LED reflects 5GHz radio is working, but Advance tab in menu reflects disabled. No SSID is showing available to any 5GHz clients. Also, I have a R7000 within the environment, which the 5GHz radio is functioning properly and showing accessible by 5GHz clients within the environment. Any ideas why this radio is not functioning?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
this is a strange one...have you tried to do a hard reset to see if that clears things up?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R9000 5Ghz Radio not enabled although LED showing enabled. 5Ghz Radio not working
If Adewale's good idea does not work, try turning the wifi switch on the device on and off.
I have seen earlier reports here of the physical switch overriding the internal wifi settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was a bit worried after spending so much on this device and after 6 months I could not get phone support without paying fees.
At any rate, I do appreciate your response and the suggested advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well done. You might like to mark Adewale's suggestion as the solution. In that way later victims can home in on the advice more quickly.
