Orbi WiFi 7 RBE973
Reply
R9000 5ghz ssid visible, but can not be connected.
GeneW
Follower
It was working fine. last week the 5G wifi suddently has issue that cant be connected from any device, but the ssid visible.  2g Wifi is working fine.  Tried reset, factory restored, downgraded firmwares couple times, but no luck.  Any help will be appreciated. Thank you.
Current firmward: V1.0.5.38 (latest)
I found the  debug page,  I have this report (5G wifi -negative temperature):
http://www.routerlogin.net/debug.htm
Basic Information
 CPU LoadCPU1: 4.47% CPU2: 4.7% CPU3: 3.81% CPU4: 4.57%
 Memory Usage(Used/Total)134MB/1006MB
 Flash Usage(Used/Total)158MB/512MB
 Network Session(Active/Total)348/65536
 CPU Temperature49
 2G WiFi Temperature54
 5G WiFi Temperature-174
 60G 11ad baseband temperature66.582
 60G 11ad antenna array temperature42.187
 System Uptime01:13:16
 Wireless driver version4.0.1756.382
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 569 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
