Reply
R9000 Auto channel 2.4ghz
Mark1281
I have a nighthawk X10 R9000 and the 2.4 GHz range has been decreasing.  The channel is currently set to auto, should it be changed to a number and if so what channel?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 5
Guru
Re: R9000 Auto channel 2.4ghz
Primary channels recommended on 2.4Ghz is 1, 6 or 11. 13 if your in the europe region.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 5
ElaineM
NETGEAR Employee Retired
Selecting wireless channels
ElaineM
NETGEAR Community Team
Message 3 of 5
Mark1281
Thanks, however mny question is specific to the Nighthawk x10 as some say the auto channel functions different and some say to select a particular channel.
Message 4 of 5
schumaku
Guru
It's impossible to answer your question. Matter of fact, the 2.4 GHz band has about three non-interfering channels of 290 MHz bandwidth each. In a crowded environment, there can be many other wireless, visible wireless, and even other users of the free band in the air - some with non-tolerant protocols. If you are living in a dense place, there will be many units in the air on both the 2.4 and the 5 GHz band. Noting the X10 can do here ... just try and work hard, like your WiFi clients.
Fixing the primary channel used makes sense if you manage multiple access points, so you can ensue your own AP don't overlap heavily.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3105 views
  • 1 kudo
  • 4 in conversation
Announcements
