Reply
R9000 - DHCP Disable
mbescher
Firmware Version 1.0.1.36
After a successful reset to factory defaults and install, when I disable the DHCP server the router can no longer be accessed from a browser on the configured IP address. I have repeated this procedure multiple times, each time with the same result. To get the router working again, I need to reset to factor defaults and repeat the installation.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 8
netwrks
Master
Re: R9000 - DHCP Disable
Before you disable DHCP, give the router an IP address..
Message 2 of 8
mbescher
I have/had already given a static LAN IP.
Message 3 of 8
netwrks
Master
What is replacing the router as a DHCP Server? Is the ip address you have given the 9000 in the same subnet as your DHCP Server?
Message 4 of 8
mbescher
I have a seperate DNS/DHCP server. Both are on the same subnet. The LAN IP on the R9000 is static (same subnet), and even the WAN IP is static (different subnet).
Message 5 of 8
ElaineM
NETGEAR Employee Retired
How is the R9000 connected to the network? Which port is being used? Using the LAN port?
ElaineM
NETGEAR Community Team
Message 6 of 8
mbescher
The R9000 is connected to the local network through LAN port 3.
Message 7 of 8
ElaineM
That's strange. I do not experience the issue with the R9000 that I have.
I suggest that you contact support and log a case.
ElaineM
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1747 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
