Orbi WiFi 7 RBE973
Reply
R9000 FIRMWARE 01.0.5.26
Dards
Initiate
Nighthawk app recommending I upgrade the firmware in the R9000 router to 1.0.5.26 but I never like to do that without first reviewing the release notes and forum comments.  No release notes available and I cannot find any comments.  Anyone have any comments on this firmware upgrade?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Guru
Re: R9000 FIRMWARE 01.0.5.26
I'm a bit impressed by this statement. Its one of the things we frequently recommend but so rarely see in action. Thanks for renewing my faith in humanity 🙂
I've seen a couple posts on it but you're always going to see a few after every firmware update. There's always a few that have issues.  I'd make a backup of your current configuration and try updating it. If there's issues, you can always downgrade, factory reset, and reinstall the backup.  That'd be the route I'd go.
Again, thanks for due diligence and giving me faith in helping others again.
Message 2 of 3
kc6108
Luminary
https://http.fw.updates1.netgear.com/r9000/ww/stringtable.dat
Looks like the latest release notes are:
[Security Fixes] This firmware addresses security vulnerabilities.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 624 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
